Crabbypatty
Apr 16, 2021Explorer
Backing up places all the weight of the TT on the hitch, especially on uneven or different surfaces. Next time straighten out, chock the trailer wheels once you get it where you want, place truck in neutral and let the tension releases from the hitch. If on a hill, you may need to place it in gear with a foot on the brake, to release a little bit. Dont go to far forward otherwise you placing tension on the hitch in another direction. I almost always place in neutral even now with fifth wheel and it takes the tension off the pin.
About RV Newbies
