1988Resort
Apr 16, 2021Explorer
opnspaces wrote:
Edit, I see you posted that you got it fixed while I was typing. But I am curious, do you have the black or silver style below. I'm leaving my post to possibly help someone else in the future.
First and foremost be careful. When you get that hitch loose it's going to drop to the ground. You definitely do not want it to land on your foot.
As asked above, leave the latch in the lock position and see if you can move the hitch around by hand. Leave it locked so it doesn't suddenly drop on your foot. If it doesn't move you have a problem. If it does move as we all expect it will, then you have a rust or binding problem.
In the pictures below does your trailer use either of the latch styles? If so which one one, the black or silver?
If the black unit then uncoupling takes two motions. You lift the back edge up exposing a small v shaped groove on the bottom of the lever. While holding the back edge up you slide the lever backwards until the v shaped groove hooks over the slot and holds the lever up when you let go. If the lever does not stay up you are not unlatched and it will never come off.
If the silver unit then the lever lifts up and stays up. If it won't uncouple after the lever is up then you possibly have a rust issue.
Apparently I need to change something in my settings to see photos, but based on the verbal description, I have the black one. Lift up and pull back (which is what I didn't realize when first attempting to dismantle).
About RV Newbies
