BarabooBob
Oct 14, 2020Explorer III
Unless you have a battery disconnect switch that is turned off or have the battery fuse in the converter removed, you almost always have a circuit wanting power. On my TT, things that are always drawing power are the CO detector and the radio (even when turned off) When you attach the battery cable, there will be a spark as the circuit is completed for these items.
About RV Newbies
