Gjac
Oct 15, 2020Explorer III
If you have a multimeter set it to 10 amps and check the amp draw. If you see several amps something is left on. If less than 1 amp it is it is normal parasitic draw. My is about .4amps and will spark when I connect my neg cable to post. Don't overfill cells with water, clean connections every so often, and clean the top of your batteries also to minimize self discharge.
About RV Newbies
