Wonder what would happen if.......
Put a 5" Clear extension on the tank outlet,,, DRAIN TANK and rinse, leave the extension on the tank and let it drain till it's all gone. Put one of the "Flush King" type vlaves (Link will be added shortly) The one I pictured is not the one I'd use if you have a tank flusher but if you don't .. Well then it IS the one I'd use.
(The one I would use (I have the Tornado tank flusher) is just the valve, no elbow, no "inlet" Pug this on the bottom of the 5".
Now, Remove the hose. Trigure a bug bomb, shove it up into the extension, and CLOSE THE VALVE below it..... GO, Look, See (Sights) dine (OUT) whatever, Come back, close main tank valve (The one you have, if there is any liquid in the extension hook up hose and open valve part way so it drains, Remove extension (Close valve first) and wearing gloves remove bug bomb, double bad and disopose of (Along with gloves) following good haz-mat procedure. Re-attache hose and other accessories as desired.
