Artum_Snowbird
Nov 11, 2015Explorer
I would go shopping for a large cardboard box that will take your freezer in it. Then go to the hardward store and buy enough rigid insulation to completely cover all walls, top and bottom, and back or front. Put the freezer into the well insulated box and try not to go into it except once every day or two to take medicine to the inside freezer. Open the freezer when you know you will have power to it, and possibly even turn the temp lower when you have power as well, then reduce the freezing when you are boondocking. Keep the freezer full, even putting in pieces of the leftover insulation to reduce the air space inside to what you need for your goods.
About RV Newbies
4,026 PostsLatest Activity: Jun 15, 2017
