Scott_85
Feb 21, 2014Explorer
Holding tank chemicals
I've search this site and read countless reviews on both CW and Amazon and I can't see which one is the best. Which chemical do you think does the best job and why?
EsoxLucius wrote:Rollnhome wrote:You may not need bacteria in the tank, but there is not much you can do about it. It will be there from your own gut. And if anaerobic bacteria proliferate (almost guaranteed within hours) bad odors will be in the tank.
FYI you don't need bacteria in your tank. They are holding tanks. The waste should not be in them long enough to breakdown.
My practice:
1. To maintain my blackwater holding tank I use two tablespoons of Happy Camper Odorless Holding Tank Treatment (53 cents) dissolved into two gallons of water dumped into an emptied blackwater tank.
2. Happy Camper is biodegradable, works in all temperatures, eliminates odor, dissolves toilet paper, liquifies waste, and keeps sensors working properly. I use any two-ply toilet paper that is safe for septic tanks.
3. Proliferation of anaerobic bacteria causes odor. Happy Camper promotes aerobic bacteria which crowds out or kills anaerobic bacteria and accelerates decomposition.
4. With Happy Camper there is no need to use excessive amounts of water. Just two gallons to start and normal use of the toilet and bathroom sink. Filling an empty black tank one-third full with water is wasteful, as is using more water than necessary to flush.
5. Happy Camper is the one blackwater tank treatment I've found that does work. No colored chemicals, no detergent, no water softener, no bleach, no chemical tablets, and no excessive amounts of water.
6. If possible, I wait until my blackwater tank is at least half full before dumping.
7. It is easy and cheap to try Happy Camper to see if it does indeed work for you.
