Scott_85ExplorerFeb 21, 2014Holding tank chemicalsI've search this site and read countless reviews on both CW and Amazon and I can't see which one is the best. Which chemical do you think does the best job and why?
1775ExplorerFeb 24, 2014I have tried the Geo Method and I have used this http://www.walmart.com/ip/Camco-TST-Holding-Tank-Chemical-1-Gallon/14504329 This chemical also has a lube to keep your tank seals lubed so you get waste breakdown, deodorizer, and tank lube in one quick treatment. And it is not expensive.Between the Geo Method and this chemical it is a toss up. The Geo Method did no better than the chemical and the chemical is more convenient.
Related ContentHolding Tank Chemicalsblack tank chemicalsHolding tank chemicalsHolding tanksHolding Tank Terminations
