Scott_85
Feb 21, 2014Explorer
Holding tank chemicals
I've search this site and read countless reviews on both CW and Amazon and I can't see which one is the best. Which chemical do you think does the best job and why?
Rollnhome wrote:You may not need bacteria in the tank, but there is not much you can do about it. It will be there from your own gut. And if anaerobic bacteria proliferate (almost guaranteed within hours) bad odors will be in the tank.
FYI you don't need bacteria in your tank. They are holding tanks. The waste should not be in them long enough to breakdown.
We Cant Wait wrote:
Have never used any chemicals and all the units I've had have never smelled like an outhouse. Use plenty of water when flushing, ensure your vent is operating properly, and toilet seals are good, and your GOOD TO GO.
Rollnhome wrote:
You will find many do not use chemicals, nor do they use RV toilet paper. The trick is to use plenty of water when you flush. Your holding tanks are a sealed system. Properly empty and flush your tanks and you will be fine.
