tatest
Oct 30, 2013Explorer II
If it is a 4-speed OD automatic, you probably could flat tow, using procedures outlined for the CRV, as that transmission was shared across the Accord, CR-V, Element, Pilot, Odyssey and some Acura models. If you do, don't expect warranty coverage for transmission failures.
With respect to other towing issues like odd tire wear and suspension wear, you would be mostly on your own. A good independent alignment shop might be willing to talk about alignment for towing, rather than for optimal handling when driving. If you find a baseplate or towing brackets for it, the manufacture of those parts will put the responsibility on you to make sure that use of what they sell you does not damage your car, but they do the same for all cars.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
