SoundGuy
Feb 19, 2019Explorer
2manytoyz wrote:
I have the Yamaha EF2400iS. It's the predecessor to the EF2400iSHC. The new model has an even higher starting capacity than the 2400iS.
That said, there's very little I can't run with mine. When it was introduced, it was designed to do what a single Honda 2KW cannot. It will reliably start, run, and restart a roof top A/C unit with a high head pressure.
I'm one of those who has successfully been able to repeatedly start a variety of 13,500 BTU A/C units, each equipped with a Supco SPP6 hard start capacitor, with the 2 different Honda EU2000i gensets that I've owned. The catch was that I'm only at ~ 250' above sea level and if temps rose beyond ~ 85F then the genset finally did reach the limits of it's ability to start these A/C units. No question about it, Yamaha's EF2400iS and it's improved EF2400iSHC both filled a gap that Honda never addressed - until now, with the recent introduction of Honda's new EU2200i which is MUCH smaller and lighter than an EF2400iSHC. If I were buying another genset so I could power an RV A/C, recharge the trailer batteries, and as back up power for the house I'd this time around invest in a new EU2200i and spend the extra $$$ not spent on the more costly EF2400iSHC instead on equipping the A/C with a MicroAir Easy Start Soft Starter Kit, the combination of which have been proven to work quite well for this task even when elevation increases and ambient temps are quite high.
About RV Newbies
