Ex-Tech
Oct 19, 2013Explorer
WyoTraveler wrote:
Not really a problem with any of the sway bars. Before unhooking use tongue jack and raise about a foot to release pressure on sway bars. Disconnect sway bars. Then lower the jack to unhook. Same way hooking up. Make sure hitch is latched. Raise jack about a foot. Connect sway bars. Then lower jack.
This is correct for the weight distribution spring bars if those bars are part of a sway control system such as the Equalizer brand but not for the friction sway controls which have no pressure on them and release by pulling spring clips.
About RV Newbies
