- jnharleyExplorerWe have a dedicated built in vented compartment for our sewer hoses/attachments in our HitchHiker. They really put a lot of thought into the design of this 5th wheel.
- AllworthExplorer IIA cheap yellow hose from WalMart.
- pappcamExplorer
Dakzuki wrote:
Nobody has mentioned it yet, but be sure to store the hoses separately. All my sewer related stuff is separated from the fresh water stuff....as in different compartments. I've seen fresh water hoses stored with sewer hoses and ....ewww.
My sewer hoses go in my back bumper and I have a sealed container for the other sewer hose parts like elbows and connectors.
My water hoses go into the storage compartment closest to the back of the TT and I connect both ends of the hoses together when I coil them up for storage. - cpaulsenExplorer III use an older white fresh water hose for my black tank flusher. When I replaced my fresh water hose.....I coiled up the old one and used black spray paint to put stripes on the old one....no mistaking one for the other.
- texasAUtigerExplorerThanks, Dakzuki. Yes, I store all my sewer related items (connectors, everything) in the rear storage compartment and everything else in the front storage. I do NOT want ANY cross-contamination!
- DakzukiExplorer IINobody has mentioned it yet, but be sure to store the hoses separately. All my sewer related stuff is separated from the fresh water stuff....as in different compartments. I've seen fresh water hoses stored with sewer hoses and ....ewww.
- itguy08ExplorerOn ours we have the "outside shower" that is really a coiled hose with a quick connect on one end and the regular garden connector on the other. I run that to the black flush and let it go. That way I can run some warm or cold water through it. That hose will never be drank from and it seems to work out well for us.
- texasAUtigerExplorerThanks everyone. It sounds like it is safe to travel with only two hoses: a dedicated freshwater hose (white) and a general purpose hose for spraying off which can also be used to backflush (green).
In case it helps any other newbies, what I did this time is connect a Y at the spigot, attached the pressure regulator to one outlet of the Y and then the white freshwater hose. On the other Y outlet, I just connected a green hose and sprayer for general wash up and camp cleanup.
At the end of the trip, I just connected the green hose to the backflush valve after dumping.
Everything seemed to work fine. It was nice to have wash up ability outside this time. - pappcamExplorerI carry a few white hoses for fresh water or drinking water and a couple of general purpose hoses that I sue for the black tank flush or other uses that aren't drinking or fresh water related.
- jnharleyExplorerWe have a dedicated hose, black in color for the black tank flush. That way, we cannot mistake it for anything else. We are full timers though so we use that hose all the time.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
