Bahcml's avatar
Bahcml
Hot Water Tank Bypass
I wish I knew how to post pictures, but I don't, it sure would save a lot of dialog. We recently got a new (to us) trailer and in looking at the hot water heater we are completely confused. It has a red line labeled Hot and a blue line labeled Cold. There is another short line that runs from a junction between the hot water tank and the red line that is attached to a short blue line, there is no valve to turn, just a junction with the blue line running down to a junction with the other (cold) blue line. This particular junction has a valve that can be turned either in line with the blue line coming into the tank labeled cold or turned to align with the short blue line running down from the red (hot) line. We suspicion that this is a bypass, but how can that be? If we were to turn the valve to keep cold water from entering tank what would keep the water from backing up and back filling the hot water tank by running up the short blue line to the red line that has no turn off valve? I guess the short questions would be "doesn't a HWT bypass require two shut off valves? Or is there a check valve in the HWT that allow water to only flow out?
    Upload your pics here, copy the url created, and paste it into your post.
