EstorilM
Jul 25, 2017Explorer
How much propane will I use?
Hi everyone! Forgive me for posting a lot lately, but I'm totally hooked after picking up my first TT and taking it on two trips already (in under a month! Technically it was for "work" though) ;)
I'm fairly familiar with everything in the unit, and how it works - but I can't really put a number on how much propane I'll use, I just have absolutely no clue.
Let's say my last trip. Each way we drove about 10hr total, 3 days there so..
20hr fridge propane
30 min runs of the hot water heater
30 min small burner
20 min oven
Also, how much does a 35,000BTU furnace use? I'd imagine quite a bit. I'll probably install a heat coil, forget which AC unit I have though. It does have the "heat" settings and such, so does that mean it's pre-wired? That and a small heater should be fine.
Both trips were basically the same, and I haven't checked the tanks. It's got 2x 40's, and I'm also not sure about the switch-over. It's auto but the lady wasn't really clear on how I'd be using / switching it.
Thanks!
20hr fridge propane
30 min small burner
20 min oven
Thanks!
