time2roll
Feb 11, 2015Nomad
cdevidal wrote:I bought the PI EMS protection after a few years and seeing low voltage a few times. Have since encountered bad ground, high voltage cut off, low voltage cut off. Not a lot but it does happen.
The more I look into this, the PI protector is a really good idea. Insurance.
Whereas buying the 50AM-30AF adapter is more like "convenience insurance" :B
The 'insurance' to me is not necessarily to protect the RV from the cost of trouble but more to prevent the loss of use if something happens while on limited vacation time. Your boss is not giving you a replacement week when your RV burns out and you return early.
But again you don't need this to go out the very first time. Outlet tester and voltmeter are pretty good determining if your connection is good.
About RV Newbies
4,026 PostsLatest Activity: Jun 15, 2017
