rockhillmanor
Feb 12, 2015Explorer
I carry this with me and check the shore station BEFORE I plug in.
I have found 'numerous' CG's that have an 'open ground' situation. These outlets are used WAY more times than a residential outlet and that is what they use, and they become loose over time and wires not tight inside. They should be using outside commercial outlets which they do not.
And sadly when I bring it to the CG's attention that the outlet has an open ground, many say that it is ok go ahead and plug in. :R
My answer is no 'I' don't want to be the 'ground for the day' and ask to be moved to another site.
About RV Newbies
4,026 PostsLatest Activity: Jun 15, 2017
