cbshoestring
Feb 14, 2015Explorer II
cdevidal wrote:
Sorry, I had in mind the other way 'round. I understand you two to be saying that the tester is redundant because the surge protector does the same job equally well, but by simply plugging in a little device you can save time not hauling out the cord first. Did I get that right?
Considering the progressive you bought, yes the little tester is technically redundant.However, it can save you a lot of aggravation since it can be used pre-setup. You coud even use it prior to backing into (onto ???) the site.
Considering how SOME of you back up----that little $10.00 item could save you hours, might make the difference between a good/bad weekend, and even save a marriage or two. Then again, my Friday evening would be less entertaining. :R
About RV Newbies
4,026 PostsLatest Activity: Jun 15, 2017
