slice38ExplorerDec 23, 2013How to Properly Winterize Suburban Water HeaterOk, I've drained my water heater totally and put in a new anode rod. To properly protect the tank, should I put a mixture of antifreeze back into the tank or is it okay to just leave it empty over th...Show More
JamesBrExplorerDec 24, 2013Once I bypass and winterize the water system and the tank is drained, I leave the annode out all winter, install it first use in the spring.
Related Contentwinterized properly?Suburban SW12DEL Water Heater On/OFF switch melts???Winterizing tips and tricksSuburban dilemmaSuburban tankless water heater winterizing
