Stepnwolf's avatar
Stepnwolf
How wide do mirrors need to be for a TT?
Hello, newbie here.
I am about to buy a trailer 750 miles away so I need to get my ducks in a row before leaving. I am looking at an Arctic Fox 22G which is a 8.5' wide trailer excluding the awning. I am driving a Sequoia and the stock mirrors are 94" to the outside edge. I bought, but haven't installed the CIPA mirror extensions which add about another 10" to the width. That puts the outside edge of the mirror barely wider than the trailer. Will these add-on mirrors be adequate?
My previous experience pulling a TT was a 1963 16' Shasta being pulled with a 66 Chevy wagon with the extended mirrors mounted with long springs to the top and bottom of the door.
My cousin with the same vehicle is pulling a Snow River but it is 8' wide. He swapped his RH mirror for an extended mirror. Not sure how much of a difference that half foot of width makes.
I just don't want to be leaving the purchase point with inadequate mirrors before the 750-mile return home.
Thanks!
  • Bigfoot and Airstream trailers are also over 8' wide. I have towed a Bigfoot with a Titan and standard mirrors. There is a wedge of a blind spot that the trailer creates relative to the mirrors in a critical area. I prefer my mirrors to extend past the side of the trailer so I can look straight down the side. Much safer and easier to back the trailer.
  • rhagfo's avatar
    rhagfo
    Explorer III
    dodge guy wrote:
    Are you certain the trailer is 8.5ft wide? The only RV type Trailers that wide are high end fifth wheels. Almost all trailers are 8ft wide.
    Well yes it is.
    Link to Arctic Fox specs
  • Seon's avatar
    Seon
    Explorer II
    camp-n-family wrote:
    Buy yourself a set of these. Tundra and Sequoia mirrors fit the same. Super easy to install too.
    Agree on the mirrors. That's what I installed on my TV.
  • Are you certain the trailer is 8.5ft wide? The only RV type Trailers that wide are high end fifth wheels. Almost all trailers are 8ft wide.
  • Check this out from AAA..............
    https://drivinglaws.aaa.com/tag/trailer-mirrors/
    I suggest you check DMV regs where you are.
