Led_67
Feb 03, 2014Explorer
fordsooperdooty wrote:
The usual 13,500 BTU or 15,000 BTU units are built and engineered for RV use. Bumpy roads, vibrations, voltage variences, exposed to weather, etc.
A window unit is supposed to sit semi-permanently mounted firmly to an window sill that DOESN'T jiggle, bounce, go 60 mph down a road and rattle it's teeth.
Which is going to last longer?
X2...Even with the unit sitting for extended periods it will still sustain damage from transport. Also think about the thermodynamics of a window unit which is designed to deliver a direct blast of air into a room vs a rooftop unit that is designed just for your rv and is already setup for maximum efficency.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
