thehippieExplorerAug 07, 2015Is it possible to drain waste ?Is it possible to drain waste tank without the sewer hose? Just let it drain to the ground I know it's disgusting but will the waste like urine come out even without the sewer hose?
Johno02ExplorerAug 08, 2015Yes, you sure can! Just be sure and look up inside the drain pipe to make sure the valve opens as you pull the valve handle.
Related ContentHouse battery drainDraining fresh water (waste of water)Raptor Black waste tank not drainingDrain Master electric waste valvesPower Drain
