mtnbbud's avatar
mtnbbud
Explorer II
Jun 04, 2015
Is using cruise control okay?
My TV is a 2001 6 cyl. Tacoma automatic with a towing package and my TT is 18ft and weighs 2900lbs dry - est. 3400 loaded. When towing, I turn off the overdrive and select the extra power button for adjusting my shift points. I usually keep my speed at 60 mph when on the level and the highway is straight-ish.
Up till now, I have avoided using the cruise control. I am going on a long trip this June that will include some long stretches on the interstate. Is it okay to use the cruise control under those situations? If so, is there anything to watch out for or be aware about?
  • wanderingbob wrote:
    I do not touch the tow button until the truck tells me to by shifting constantly .
    Really? I was told to turn the Tow/Haul function on whenever I towed the TT. Have I been doing this wrong?
  • I do not touch the tow button until the truck tells me to by shifting constantly .
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Probably depends on the vehicle, but I use the CC every trip with my Tundra.
  • RoyB's avatar
    RoyB
    Explorer II
    We will switch to cruise control on the long level roadways. When we get into the hills however and the truck starts talking you then of course we switch it out then.
    Roy Ken
  • dvitale300 wrote:
    I've been meaning to post this question for a while - I'm glad it's hear. I'm towing with a 2009 Dodge ram 5.9L hemi. I am a little near the weight limit when fully loaded so avoid traveling with full tanks / etc. I've heard (somewhere on this board) that when you're in hilly country it's best to stay out of cruise control and manually control speed up hills. Is that good advice?
    The manual for my 5.7L hemi (2013 ram 1500) states to stop using cruise control if speed drops more than 8mph going up a hill. I'm way under in terms of towing weight but at the line payload wise. I haven't met a grade yet that the hemi can't climb and hold the cruising speed. Some of the steepest grades in Canada and Alaska had the computer shifting into 2nd gear and the engine was roaring, but hey, that's what it's made for right?
  • I've been meaning to post this question for a while - I'm glad it's hear. I'm towing with a 2009 Dodge ram 5.9L hemi. I am a little near the weight limit when fully loaded so avoid traveling with full tanks / etc. I've heard (somewhere on this board) that when you're in hilly country it's best to stay out of cruise control and manually control speed up hills. Is that good advice?
  • Your operators manual is the best source of information for such a question, with regards to towing.
    When I started, I pulled my camper very similar to yours with a 6 cyl station wagon. I set the cruise for 55-60 and shifted the trans into "sport" mode, which the operator manual pointed out delivers more low end torque and was recommended for "spirited" driving, towing and hilly terrain.
    Since your Tacoma has the towing package and towing button, hit it and let the computer worry about your transmission... no need to turn off the overdrive unless instructed by your operators manual.
  • I use mine all the time. so long as the transmission doesn't hunt for gears all the time it is OK to use it.
