kellybell's avatar
kellybell
Just getting started - questions
Hi all! I am just getting started in RVs, and I want to restore an older one that is not working. I have restored many old cars, so I am not completely blind to what I can do and not do. I have some questions:
1. I am looking for a pop up camper, so I was wondering id there a specific brand I should look for? Or are they all the same?
2. What should I look for in a used pop up camper?
3. I do not need one with ac or even a shower, as I am planning on only over night camping.
Any input you may have would be appreciated!
Kelly
  • Look for one that has no leaks...look at the roof and make sure it closes and seals good. Make sure the roof doesn't sag. Depending on the age of the pop up, you might want to replace the canvas. Expect to spend in upwards of up to $1000 or so for it. We bought a used pop up a couple years ago that we were going to use in the mountains while our TT was stored at the beach. I looked and looked on craigslist. Some people think their nasty old rotting pop ups are made of gold. I finally found a 2001 Coleman that was in really good condition. I bought it for a couple thousand dollars. The bad part was that the people stored moth balls in it. Kept it a month before trading it and the TT in on our Class C. Dealer put it on the lot for over $5000. Not sure what it sold for. But if it was any indication of what others were wanting for theirs, then they might of got it.
  • Never been a popup owner but many years with boats & canvas.
    As said by many, look at the canvas & look for evidence of leaks, current & former.
  • I also suggest that you post in the pop up section. I had a used pop up and when I was looking, I was most concerned about the canvas. What kind of shape was it in. Did it fit well on the frame. Was it easy to put up and did it stretch properly. Did the door fit well.
  • The biggest issues with popups, are canvas condition and roof problems.
    remember, canvas makes up most of trailer.
    Suggest you check out the Popup/Tent Trailer section here and ask for input there.
  • I would look especially hard for water damage. Wood can be replaced. But if the tailer has extensive structural damage, you may be in for a complete rebuild, if even possible or feasible.
  • DrewE's avatar
    DrewE
    Explorer III
    What do you have in mind for "restoration" entailing?
    I would look for a trailer with good canvas and with no signs of water damage (particularly to the floor), either of which would be expensive and/or involved to repair. I would also at least check the trailer weight vs. my tow vehicles capabilities, and look for good running gear.
    I think the A-liner trailers look pretty nice myself, though I've never actually used one, only peeked in at RV shows. They aren't traditional popup trailers, of course, but a fairly close kin.
  • Kelly
    DW and I bought a popup a couple years ago. Because of size, options are somewhat limited.
    Since we live in Texas, AC is a must. After we bought it and took it camping a couple times, we invested in solar covers for the bunk ends (www.popupgizmos.com). They make a big difference if you aren't parking under shade.
    It also has a built in toilette (cassette model) which comes in very handy ILO middle of the night treks to the bathhouse. Most have an outside shower, but if you are campgrounds you can usually find a bathhouse with showers.
    You might want to look for one with a dinette slide-out - makes for more room inside. Also look to see what available outside storage there is as when it is down for travel, there is very little space inside.
    Don
  • I would not rule out the shower or A/C- you might find yourself going out longer than overnight and they might be nice to have. JMHO
  • Kelly,
    Pick one with a floor plan you like. Many have seating you have to crawl over to get into bed. Some mind that, others don't.
