Deb_and_Ed_M
Nov 18, 2015Explorer II
A couple of thoughts:
What color is your RV? If it's white, you might be surprised at how long it takes to get uncomfortably-hot without the A/C running. If it's a dark color, it's going to heat up quickly, unless it's heavily shaded. You can cut Reflectix insulation (like bubble-wrap, with foil faces) to fit in the windows that will be facing the sun, to help keep it cooler, too. Just sitting out in a field with the windows covered in Reflectix, our white 5er never got above the ambient temperature during a Michigan summer with temps in the 90's; and usually felt about 10 degrees cooler, IMO.
What breed/type are your pets? A short-faced dog like a Shih-Tzu will overheat before a long-nosed Poodle will.
I agree with Naio, if your pets have access to water and a cool breeze via 12v, they should be able to endure a loss of power. On a hot day, maybe have a neighbor simply listen to make sure they hear the A/C running from time to time?
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
