zorky wrote:
One more question is do you only turn on the hot water heater when your lines are full of water? I don't want to burn anything up. The dealer really explained nothing.
Yes. Do not turn on the water heater if its tank is empty.
If you're starting with a drained system (which, for the water heater, can be readily verified by removing the drain plug), you fill the water heater by turning on water and opening a hot tap somewhere. A lot of air will come out the tap, as the water fills the heater tank and the air is displaced. When eventually you have water coming out, you have a full water heater tank and can turn on the heater.
If you get water coming out the tap within just a few seconds, the water heater is probably bypassed and still dry.
Some people use the relief valve on the water heater to let the air out rather than a hot water tap somewhere. The basic idea is the same.
If you have an electric element in the water heater and run it dry, the electric element will burn out very quickly (as in seconds). If you run it on gas, a safety thermostat thingy can rather quickly operate...and it's generally a one-time use device, and somewhat expensive and involved to replace. Don't dry fire the water heater.
