zorky's avatar
zorky
Leave water on ?
Hello all. I am a newbie to owning a travel trailer. I have not used it yet. I searched the forum and could not find this. Can someone answer? My trailer has a fresh water and potable water inlet. The question is for full hookup do I hook up the fresh water and leave the water on at the spigot? Or do I fill the fresh water tank, then turn off the spigot, as fill as the tank empties? I know I am suppose to leave the black tank closed and the gray tank open. Thank you
  • We leave the water on. If we take a day trip away from the CG we turn the water off before we leave. We very seldom use our onboard water tank. Usually only enough for a few toilet flushes while traveling.
    Waste: I'm with Old-Biscuit.
  • Personally........
    I fill fresh water tank and use my pump.
    1) If pump occasionally 'burrups' then I know there is a minor leak/issue cause line pressure should not drop unless faucet/toilet/shower is used
    2) Don't have to be concerned with CG water pressure issues
    As for Waste tanks.......
    I never leave any open cause sewer flies can come up into waste tank, set up home, have babies, invite cousins to join in.
    Some will put a dip in sewer hose so that a water trap is made but I like dumping when tanks are FULL and that means having to remember at least a day ahead to close off grey dump valve.
    I'm just not into all that remembering of stuff when out enjoying/relaxing with my trailer-----I like Simple.
