mlts22
Aug 17, 2015Explorer II
I think this thread says it all... A multi-stage converter or a Battery Minder.
Only thing I would consider adding is having an EMS hard-wired in, which will stop the RV from frying if plugged into a 240 volt dryer outlet, as well as save the A/C compressor if a CG has too low a voltage. The reason for it to be hard-wired in is that there is no way to forget about plugging it in, and it is out of reach for all but the most determined of thieves.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
