Rmack1's avatar
Rmack1
Long-term parking effects on tires
A friend advised me that I shouldn't leave my new TT parked for long periods right on the ground. He recommended pieces of plywood cut to insulate the tires from the ground. His understanding is that some types of soil can leach moisture from the tires, causing them to crack and wear.
Anyone confirm this? Does this include concrete or asphalt? How about gravel? I noticed some of the small rocks stuck to my tire for a few revs after it was parked a couple of months, which was disconcerting, but didn't seem to do any damage.
How long is long term?
I have my two-axle trailer parked on gravel. No one else in the storage facility seems to have their tires on anything but the asphalt or gravel. Many are much longer term than my two or three months between trips.
BTW, I know about solar damage. Tire covers of one sort or the other when the rubber is exposed to the sun seems universally agreed upon as being a good idea.
  • Some good ideas and some "overkill" also...Funny that the rv lot's can leave these units setting in one place for months and months on end, not leveled, with all slides out, never checking the tire pressure, until they sell them, (IF THEN), and yet, we buy them and drive off the lot not thinking much about any of that. I purchased my 06', brand new off the lot in Oct. of 07'. It set for almost a year. when I purchased it. I made sure tires were aired to recommended psi, and I've really had no issues to amount to much of anything, and it is 7 yrs old.
    I keep mine parked on concrete when camping, if at home, which is gravel, I drive up on 2 X 12 X 6 ft. pressure treated lumber and cover the tires.....never have raised the unit off the ground to take pressure off tires or axle no matter how long it set...
  • I've had mine at an RV site for about 10 months with tire covers. About every three months I jack it up one wheel at a time and rotate the wheels to avoid flat spots on the tires. I'm not sure it helps and I don't know if the tires would develop a flat spot, but it makes me feel better.
  • I parked mine on a concrete pad first week of March last year, kept tires aired to 110 psi, (G rated tires), and didn't move it until after thanksgiving when I towed it 255 miles home. I had the tires covered till the week of thanksgiving...checked air in all tires, and drove it out of there, no problems, no issues, no flat spots, nothing....Towed on interstate at 60-65 mph, again, no problems and 5er had set almost 9 months..
  • If you're going to park long term on any surface the preferred surfaces are (in order)
    1) Asphalt (will not leach out the petroleum products in your tires as quickly)
    2) Concrete
    3) Gravel
    4) Wood or Lynx Levelers
    5) Dirt or sand (will leach away the petroleum products in your tires quickly)
    WoodGlue
  • Just to let you know my experience, my 5er has been parked on gravel all winter(OCT.-MAR.) since new. Not one tire failure or anything else with them. I just replaced them this past SEPT. before we went on a big trip. Tire date code was 24804.
  • Rolling the unit forward or backward a few feet, every month is a good idea. If you can't do that because of the parking situation, then jacking it up and rotating the tire as TX Tiger mentioned is the way to go.
  • Make sure to add pure nitrogen to them. Helium would be better as it will help take some weight off the treads.
