fun2rv's avatar
fun2rv
Loud explosion while backwashing black tank
Today I was doing my regular duty of emptying/backwashing the black water tank. I had emptied both the grey and black tanks and was in the process of backwashing the black tank. Now I know it says not to run the tank sprayer with the black tank shut, but I have always done this and watched the level of the water and shut it off to empty. Of course there has been the couple of occasions that I forgot the time and of course the water has always just gone up thru the toilet and made a mess inside. Thankfully it has always been after I have emptied and rinsed the tank out. But today, the tank wasn't quite full yet and all at once there was a loud boom (like explosion) and water started pouring out of the underbelly of the trailer (2002 3280 Montana 5th wheel). No water came out thru the toilet at all. It was getting late, so I wasn't able to take the underbelly covering off to inspect any of the tanks - will try to do that first of the week. I went on and made sure all the water quit running and made sure the water supply was off and left it alone. Does anyone have any ideas what happened and where or what I should start looking for first? Appreciate any and all help.
  • A commonly reported failure on the black tank flush systems is the failure (rupture) of the black tank flush vacuum breaker/anti siphon valve. The valve is typically plastic and located either inside an interior wall or under the bathroom sink as it has to be some level higher than the black tank itself. Mine fractured and water poured out the bottom of the trailer, but some water came out inside the trailer also.
    But I don't remember any one saying there was a loud boom when it failed.
  • Does sound like a ruptured tank. There was a large volume of water? You might see if your insurance will cover repairs? Just curious what the capacity of the tank is? Are they really that fragile?
  • fun2rv wrote:
    ..... there has been the couple of occasions that I forgot the time and of course the water has always just gone up thru the toilet and made a mess inside.
    Just an FYI - In a properly sealed system, the water will flow out the vent pipe, not the toilet. I have plenty of experience with that using my Flush King.
    Can't tell you what caused your current failure, but I will say I wouldn't rely on my inside indicators when judging tank levels.
  • The same thing happened to me, unfortunately your black tank will probably need to be replaced, mine did. It wasn't cheap and it took about two months to get it shipped, it ruined my summer.
    Mine broke jest below where it attaches to the toilet.
    I wish I had better news. Good luck.
  • It sounds like your tank ruptured. If your lucky maybe it was only the water line to the flusher. You still gotta open it up to see what happened. good luck.
