JohnG4706 wrote:
Just got my new travel trailer and have seen recommendations from others on getting a countertop portable ice maker.
Will the freezer get cold enough to make ice cubes if I use ice cube trays?
I assume (since you did not say) you have a standard Absorption Cooling Unit type Fridge (Dometic or Norcold more than likely) These can run off either Electric or Propane.
Many Class A's. come with a standard U-line Ice Maker, so yes the freezer does indeed get cold enough.. When the U-line water line split I took it out and put in ice cube trays.
