dvitale300
May 22, 2015Explorer
OK - not gonna charge for this ;o)
Go to Walmart and buy 3 pairs of suspenders - the ones with the metal clasp that holds the two belts together. Then, with a wire cutters, cut off the claps. You now have 6 elastic bands with graspers on each end.
Take your bed and slide if off the platform onto the floor (on its' edge). Put the bottom sheet on (the one with the elastic corners). Next fasten two belts lengthwise and 3 crosswise, adjusting the belts so that they have tension and pull the bottom sheet towards each other on the underneath of the bed. You now have a perfectly fitted bottom sheet that won't slide or come off. The rest of the bed making is as normal.
About RV Newbies
