lizzie
May 22, 2015Explorer
How to Make Up an RV Bed: I have posted this before but I guess it is time to do it again. Step l: Take a fitted bottom sheet of the appropriate size and climb up on the bed. Crawl to the head of the bed and slip the fitted corners of the sheets over the corners of the bed. You may hold the left corner in your mouth while crawling to the right corner. Crawl off the bed and go repair the fingernail you broke. Crawl back up on the bed and gently pull the sheet (now secured at the corners) toward you while crawling backward. Go back and tuck in the corner that came loose. Decide whether to fix the second broken fingernail now or wait until later. When you reach the bottom of the bed, carefully step off and firmly pull the sheet toward you. When one of the top corners pops off, repeat Step 1 as many times as necessary. If you ever succeed in getting the top corners to stay fitted, you may secure the bottom one. Then you start over with Step 1 for each successive piece of bedding (top sheet, comforter, blanket, etc), only now your objective is to get the tops to stay flat while you backcrawl to the bottom. Or you can follow the suggestion above: "Just put your camping bedding on top of it",....and go have some fun! lizzie
About RV Newbies
