bsinmich
Apr 28, 2014Explorer
In '96 Chevrolet moved to the Vortec 454 which was a huge improvement. Make sure that the chassis is the same as the coach year if you use that as an important criteria. Many coaches are on 1-2 year old chassis. Delamination means the glue in the walls is not holding anymore. This is usually caused by roof leaks. That is a very expensive or time consuming job to repair.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
