Fishinghat
Jul 24, 2014Explorer II
I would seriously consider a used diesel pusher to get the towing capacity you are looking for. You are probably also going to want to haul your merchandise in the Avalanche to allow more room in the coach, so a 10,000 lb capacity might be closer to your needs.
As for a diesel, I'd look for a Cummins ISC or ISL, as the ISB may be taxed pulling a heavy load along with the weight of the coach. Otherwise, the ISB would be just fine if you tow a light load or don't overload the coach.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
