jplante4
Jun 04, 2017Explorer II
If you get 2 - 6v golf cart batteries wired in series you can get 225 amp hours of 12v power, running them down to 50 percent will get you 125 ah before you need to charge. You can estimate the usage of your electronics and see if that will be enough. If you decide to get an inverter, get at least a 2000 watt one so you can up the batteries later.
Even with double that battery storage, I don't use the inverter or the coffee maker on battery. I have a Melita for coffee, and if I need the m'wave, the generator comes on.
About RV Newbies
