theoldwizard1
Jun 04, 2017Explorer II
Batteries, inverter, generator. You are going to need them all !
At a MINIMUM you will need 2 golf cart batteries. 4 would be better, or you can go with a couple of solar/renewable energy batteries like Trojan J200-RE or L16RE-B. Key to long battery life is a good multi-stage charger, either stand alone or built in to your converter.
You can probably go with a smaller pure sine wave inverter, say 1,000-1,500 watt peak.
The Honda EU2000i is the "gold standard", but it may or may not be enough to run your A/C. A Champion 3400 is bigger, heavier, but it costs less and will run pretty much any A/C.
Long term, you can think about solar power.
About RV Newbies
