azrving
Jun 30, 2015Explorer
Take your time. Look at the TT first then see what size truck you need. Often times you are better off with a 3/4 ton as it let's you pull many different rigs. If you are out shopping and you run across a TT that is a little larger than planned a 3/4 makes it an easy pull.
If you want to run the ac often, you may want to stay in a park. If you want to occasionally run the ac you can often times do it with a quiet 3000 inverter type generator. RVs are primarily designed to move with the seasons. Solar will provide for all your needs except the ac. You can run the heavier loads like the hair dryer, toaster or microwave off the generator or use a large enough inverter. A good large inverter gets pricey and larger ones require more batteries like at least 4 six volts or 6 six volts.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
