My hubby and I are buying a new TT this year. If you factory order a TT, do you lose bargaining power? if so, does it make sense to buy what is on the lot and add options later?
I just do not get newbies buying a new unit. You must have money to burn. No matter what a deal you get the deprecation will put you in the hole. Research and spend time looking for used. If you need spend a few $ with a mobile or dealer to inspect. There are a lot of good used out there that have the bugs already worked out. If you have to finance it is even a worse situation.
