wa8yxm
Feb 21, 2020Explorer III
about 2000 watt generator recommendations and logic.
First an inverter generator.. Sweet clean power Yes they cost more but they are clean and the non-inverter "Contractor" grade if you look at the power waveform they can be quite scary.
The inverter generators are also way easier on the ears than the contractor types. IN fact all "enclosed" generators are but fully enclosed traditionals generally stop at 1000 watts.
Plus Inverter generators can be used in Tandem (Two in parallel) so if you need say 3500 watts to kick start an air conditioner. A pair of them with a parallel kit.. Job done.
Now brands. HONDA is a very well known, established and EXPENSIVE brand but unlike all the others they have a genuine honest to need fuel pump.. and an "optionally sealed" gas tank (you open a vent before you start or it stops after a short run).
You can replace the gas cap with another that has a hose attached to an "Extended run" tank Run it for a lot more hours from the extended run tank.
Now Yahama claims they have a better designed (longer life) engine also about the same price... I'm not sure the Fuel Pump is not the more important thing.
Several "Knock off" brands such as Harbor Freight Predator, Champion and others have mixed reviews. but mostly good.
About the only ones I'd go against are the 2-stroke engine types and Kipor due to differences in the sound quality.. They may well be no louder on a DB meter but the QUALITY of the sound is different and .. Well Much more annoying.
About RV Newbies
