mlts22
Oct 21, 2013Explorer II
I have a 3000 watt Yamaha, which is a great unit. However, if I were to do it again, I'd buy the 4500 watt model or two 2000 watt Hondas. The reason is that with a 15000 BTU A/C, it can be iffish if the 3000 watt model can handle the locked rotor amps of the A/C. Two Hondas give you 3500 watts, which is enough headroom for almost any single A/C unit. Plus, if you need another 1250-1500 watts, you can buy a third 2000 watt Honda and the triple parallel kit from Wise Sales.
The Hondas give you a lot of flexibility as mentioned above. Plus, you have some fault tolerance as well.
About RV Newbies
