Lantley
Aug 19, 2014Nomad
pitch wrote:
Not complicated at all if you have matching generators that are designed for it. Simple 3 wire harness/one ground two live leads. Google Honda parallel kit.
I agree they are not complicated, however dual units require more set up than a single unit, particularly if you need to use extended run tanks.
I went the built in route simply to have push button convenience.
No gas cans,no lifting no set up at all. Convenience is a factor often overlooked in the genset discussions.
About RV Newbies
