bikendan
Jan 21, 2018Explorer
Suggest you go to some websites that discuss the two separate RV electrical systems and read through them.
12v DC and 110v AC are the two systems.
The 12 Volt Side of Life is one of them.
As was said, the furnace uses propane to produce heat and 12v battery power to ignite the propane. the furnace is the biggest eater of 12v battery power.
There is no electric heat, unless your a/c has heat pump/strip, which would require shore power or generator to run.
About RV Newbies
