er78mph wrote:
I was saying that my current hitch ball size is 2 5/16, so maybe a coupler adjustment?
I know on 2 inch and smaller you can adjust the coupler by tightening and loosening the nut, but after thinking about it again I'm not so sure the 2-5/16 can be adjusted. I'll have to take a look
during the day.
What you might do is couple the trailer to the TV and raise the trailer tongue using the tongue jack. It it lifts the rear of the truck without the ball pulling out, then it's probably okay. This what you normally do when connecting the spring bars. If it pops loose you might need to see if it can be adjusted or if you can replace the latch assembly.
Another thing is to check and see if the latch assembly is completely engaging. I've had to giggle mine a few times to get it to fully engage. I keep a rubber mallet behind the driver's seat. I use it to bust up bags of ice that are frozen solid and to rap on the side of the couple when the latch is stuck, not fully engaging or the ball won't release from the coupler.
Don't forget to grease the latch lever a little to help it move easier. I am however in the "I never grease my balls" group of trailer owners.
