Chaz59ExplorerJul 23, 2016O Grill ConnectionDoes anyone know if the o grill 1000 will hook up to my standard size propane tank? Or does it take a special fitting? Thank you!
wa8yxmExplorer IIIJul 24, 2016Any grill that uses disposable bottles can be connected to a large refillable tank or to an RV's Propane system using the proper hoseDoes not matter the make so long as it uses the standard Disposable cylinders like a Benz-O-Matic propane torch uses. Does this help.. ANY make, Any model, NO exceptions.
Related ContentGrill gas connectConnecting grill to quick connectLP Grill Connectiongrill connection to propane tankGrill modification (removing regulator) for quick connect?
