Dodge didn't make a 460. A 318 is unlikely to be in a 24 foot coach.
It could be a 360, or a 413, or a 400, or a 440.
I have seen Class C and Class A coaches with those engines.
Look under the hood, and on the radiator frame. There may be data plates there that will give the engine model. Under the hood might be a "build sheet" that lists what was put on the cutaway chassis by Dodge. On top of the radiator frame there might be an emissions sticker that tells what emissions equipment was built on the engine, and what engine it is.
IIRC, the engine model is stamped on a flat surface at the right front of the block. It will probably be impossible to see in a Class C, unless you are used to using an inspection mirror.
A 360 may have a 4 barrel carb.
A 400 will probably have a 2 barrel carb.
A 440 will have a 4 barrel carb.
I'm not sure about a 413.
