Old-Biscuit wrote:
gafidler wrote:
Go to walmart buy disposal oil drain pan about $6, buy oil and filter, lift MH on jacks/levers, drain oil , take pan back to walmart.
That's the ticket.....yeah boy
They will accept your used oil and pan?
The rig is an Ford F53 chassis and if you have ever changed oil on one, you know that the oil pan plug and filter drain directly over the front axle, making a mess if you don't build some sort of flow diverter to direct the draining oil. Just plain messy. A petcock for the pan is fine but it does not help with the filter mess.
I was under the impression that most RV parks frowned on doing maintenance on their grounds.
Also, I pull a Toad which puts added strain on the engine, which has about 50,000 mi on it.
I was thinking changing at 5,000 mi.
Thanks again all.
