Old-Biscuit
Apr 26, 2014Explorer III
Sounds like you are connected to city water source via a hose.......
The pump internal check valve is leaking allowing water from city water source to backflow thru pump into your fresh water tank.......overfilling it and it overflowed.
That is where your 'leak' has come from
The lack of water pressure....
That is because the internal check valve in the city water connection has jammed and is not allowing water in anymore....it did but now is stuck/failed.
About RV Newbies
