pitch
Nov 28, 2013Explorer II
NOT OSHA APPROVED!!!!! Loosen your gas cap, open the line between your filter and tank. Give a shot of compressed air backwards into the tank(small shot 10 or 15 # max for a second.) Gas may erupt from the tank beware.
My thinking is that if it is just gravity feed from the tank to the filter you may have a blockage.
Having this problem with 3/4 tank sucks. Either drive the tank down or feed the ONAN from a remote source if you need the generator.
Another thought; Ethanol gas may not be compatible with your lines and they have broken down internally.
About RV Newbies
