baldyman1974's avatar
baldyman1974
outside lite
I have 1989 bounder class a have outside lite on drivers side, how do I turn it on can't find switch any where, also switch in bathroom wall is that for water pump? please help
  • I looked all over for the switch for one of our outside lights. Could not find it so did not use it for years.
    Embarrassed to say there was a small switch under the light. Did not turn on where the other outside light switches were.
  • Light for bounder class A on drivers side is in electrical panel...
    switch in bath??? Where is this switch? What color?
  • Light switch is probably on the instrument panel at least it is on my Southwiind which is very similar to the Bounder. The switch may be the same switch as the master for all the compartment lights.
    If the switch you are referring to is below the sink all by itself then Yes it is for the water pump
